Hello friends, ask if you can help me please: I found a script in the forum to remove duplicate users in the vpn but this script does not work for me, as I show it in the image, it is what I would need “if there is more than one instance I took it out of a user”
If you set only-one=yes in the PPP profile used by a PPPoE or VPN server then only one connection can be established.
First of all, thank you very much for the prompt response. If indeed I did locate the option you told me, could you help me with the script please?
There is no scripting needed, with only-one=yes a user cannot establish more than one connection.
