I’m switching from using PfSense and HAProxy (which was installed on the PfSense Box) to a Mikrotik RB5009.
The Nginx Proxy Manager is on a TrueNAS scale box and is at 192.168.2.1. The http port is 192.168.2.1:10583, and https is 192.168.2.1:10584.
Nginx Proxy Manager hosts the LetsEncrypt certificates.
I used Port Mapping inside Winbox to send port 80-> 192.168.2.1:10583, and 443-> 192.168.2.1:10584.
It works as expected from outside the LAN, but it doesn’t work inside the LAN. Aa DNS static mapping directly to the webserver isn’t going to work, because I need the Nginx Proxy manager to host the certificates.
Is there a way to do this with RouterOS?
