I have never seen a Lobometrics device, so I can’t help you. If there is a RouterBOARD inside, replacing the miniPCi is very easy. Just open the box first.
Good night. I have a little problem. I bought one which came with Lobo912
a RB411U, firmware 3.30 and a wifi module CM9 100mW. Well, with this
configuration, network scanning was available to me, and was about 70.
Yesterday I decided to upgrade the board to firm 4.17, so I recognize the
R52NM card also acquired in 34Telecom. Everything went right and
recognized, but now, when scanning only detects 20 networks. I
say that the settings are exactly the same as above (Ap-
Bridge, 2.4 GHz b / g, 2442, …).
Is it possible that the card is not working properly?. I ask
this, because the card has 2 MMCX connectors, and does not indicate what each
one. I then connected the pigtail (MMCX - N / H) to one of the connectors and me
gives this result.
Should I change to another MMCX connector wireless card, or is
there is something configured correctly?
