Ubiq has released a NAS with this 3U rack formfactor and I’d love a ROSE with the same.
16 3.5” Slots with fans and dual power.
Mikrotik wouldn’t even need to add the multiple 100/25/10SPF and ethernet ports found on the NVME rose. (1-2 25GbE or 2 10GbE ports for link aggregation (LACP)) would be more than enough for the HDDs.
RouterOS mode - Running native ROSE
JBOD mode - just hook directly into the NVME rose server using the SFF ports.
Although one could just load CHR/bare metal on an old Dell or SuperMicro JBOD host. At that point, might as well just run TrueNAS on it and export what you want via NVME…
And that would almost certainly work much better than ROSE (even if one would take ROSE from year 2030). ROS box without multiple (routed) interfaces doesn't make much sense to me.
MikroTik states SFF8644 for PCIe. I've got some SFF8644 to Oculink cables and adapters to try and load up external NICs (for a different project) and so far, nothing I've found works (at least, nothing shows up in the hardware list / lspci). Not sure if it's a pinout issue or what.
Synology has some PCIe expansions. I'm curious if the Ubiquiti ones are PCIe or SAS.
