I would like to install Dude server package
My router model is CCR2116-12G-4S+, Architecture is arm64 and Version is 7.14.3 (stable).
but which options i need to install? Can anyone suggest me please?
Download extra packages for arm64.
Within it you will find dude.
And… then copy the dude.npk to the root of the Files & reboot. You need to enable it Dude > Settings and pick a path to store the database. You’d need the Dude client for Windows to then manage it, using same RouterOS login in Dude app.
Many thanks for your great support. it solves my issue.
Thanks for your guidance. I appreciate !
