Hi, is it possible that my RB1100x2AH doesn’t have a reset button?
Let me preempt this by saying: I’m not a qualified technician like most of you. I like to consider myself as an advanced user/tweaker. I looked everywhere on my case and it doesn’t have a reset button nor a hole to reach the reset button on the board. Is the only way to reach it by opening the case? Is that correct?
Why am I trying to reset it? Well,
2 rookie mistakes in a row:
- I made a typo when putting in the static IP
- and I turned on the hotspot feature without having a login/password
So now I’ve got port1 as the uplink (with the wrong IP settings) and the remaining ports (2 → 13) are in bridge with hotspot turned on (without a valid password). So, if I plug the the uplink port to another router, I can’t see the RB1100 because I’ve got no idea what typo I made. When I connect to any other port, I end up in the login of the hotspot with a user/password that I’ve got no idea what it is.
Slightly ashamed of myself
How can I fix this situation? Netinstall? Open case and reset? Is there another way around? Is there a standard password for the hotspot? I’ve tried tons of different passwords, but no luck.
