Hi all!
How can i reset the TX/RX bytes on interface?
Pat
Hi all!
Pat
From the CLI.
reset-counters <interface name>
It does not work…
interface ethernet reset-counters <interface name>
that is what i did…
Pat
Hi, I’ve seen on Winbox:
Interface list → Interface window → Traffic
or
Wireless tables → Interface window → Traffic
there is “Tx/Rx Bytes” counter.
two questions:
Has anyone found an answer for this? I’d like to use these counters to track data usage per subscriber (VLAN), and reset them to zero at the start of every month. I can’t figure out how to reset them, short of rebooting the router.
That would not be reliable anyway, as your counters would get reset at a reboot.
What you need to do is:
This is a mechanism that is present in some SNMP monitoring packages.
I need to reset interface vlan counters every month too.
Has anyone make this?
Best
