Resetting 3G connection (not PPP) when 3G signal is poor
Hi All
Im playing around using a 3G modem and have found that that a Mikrotik doesnt work anywhere near as well as a MiFi device when using 3g (through no fault of its own). The modems need to be told to re-associate with the cells when the signal drops otherwise they just stick with a very low signal and you lose 3G connection and the ability to pass data.
Is anyone running 3G , and would they be prepared to share any scripts they are using to reset the modems?
