Hi guys, as I am using mikrotik API from a long time, I wanted to check new REST API over HTTPS. So far it works great for me, and I am changing all my systems from regular API to REST API.
Since I did not found any ready to use PHP class solution, I checked HELP page here:
https://help.mikrotik.com/docs/display/ROS/REST+API
And created small PHP Class with several function to read, add, update, delete data. You can find it on github, with example script for usage
