REST API - Send SMS
I have a mikrotik router with LTE interface. I want to send SMS via REST API, but I’m not able to be success.
This command runs OK:
curl -k -u admin: 'https://192.168.8.95/rest/tool/sms'
With this result:
{"allowed-number":"","auto-erase":"false","channel":"0","last-ussd":"","port":"lte1","receive-enabled":"true","secret":"","sim-pin":"","status":"running"}
I am trying to send SMS with this command:
curl -k -u admin: 'https://192.168.8.95/rest/tool/sms/send?phone-number:+420123123123&message=OK'
I got this error
{"error":500,"message":"Internal Server Error"}
Could anyone help me please?
Thank you
Tomas
The next script should help you:
https://gist.github.com/elico/2755efac14ed47a0dee59e186e176ed8
#!/usr/bin/env bash
ALLOWED_NUMBERS_FILE="destinations.txt"
MOBILE_NUMBER="$1"
DRY_RUN="0"
if [ -f "dry-run" ];then
        DRY_RUN="1"
        echo "### RUNNING IN DRY RUN MODE ###"
        echo
        echo
fi
if [ -z "${MOBILE_NUMBER}" ];then
        echo "Missing mobile number"
        exit 1
fi
grep "${MOBILE_NUMBER}" "${ALLOWED_NUMBERS_FILE}" >/dev/null
if [ "$?" -gt "0" ];then
        echo "This mobile number: \"${MOBILE_NUMBER}\" is not allowed"
        exit 3
fi
MSG="$2"
if [ -z "${MSG}" ];then
        echo "Missing message text to send in the sms"
        exit 2
fi
USER="admin"
PASSWORD="1234"
LTE_ROUTER_ADDRESS="192.168.88.1"
URL="https://${LTE_ROUTER_ADDRESS}/rest/tool/sms/send"
echo "Sending sms to: \"${MOBILE_NUMBER}\" via URL: \"${URL}\""
echo "Message: \"${MSG}\""
JSON_DATA="{\"port\" : \"lte1\", \"message\" : \"${MSG}\", \"phone-number\" : \"${MOBILE_NUMBER}\"}"
if [ "${DRY_RUN}" -eq "0" ];then
        curl -k -u ${USER}:${PASSWORD} ${URL} \
                -H "Content-Type: application/json" \
                --data "${JSON_DATA}"
else
        echo
        echo "DRY RUN, should send the next JSON to the LTE Router"
        echo
        echo "${JSON_DATA}"
fi
curl -k -u admin:password -X POST rouer_ip/rest/tool/sms/send --data '{"port":"port","phone-number":"phone_no","message":"message"}' -H "content-type: application/json"
password - if not set leave empty
rouer_ip - for example: 192.168.88.1
port - for example: lte1 or usb1
phone_no - phone number (can contain country prefix)
message - text to send
