The rnd 50:50 probe seems to fail a lot on my network
What is it and how do I disable it?
Do I need it?
THanks,
Aaron
Same with me ?!
Ditto
rnd - random. It will decide services status using random number generator.
For debugging purposes only.
How do I get rid of it ?
When I delete it it just comes back after a few days.
Thanks,
Aaron
You do not have to get rid of it. Just do not assign it to any device and it won’t bother you.
I dont assign the randon 50:50 probe to any item it just detects it automatically. I remove it and it comes back with the next network scan.
If I assign a device type to and make sure that the 50:50 probe is not checked then it does not come back.
Crazy
Remove it from the list of ‘to be discovered’ services (Server Configuration → Discover tab → Services section) if you don’t want it automatically assigned…
In probe settings you can specify probability of OK status. Set it to 100 and you are done ![]()
