Many thanks you for your help. I tried your settings, and after making a few adjustments to the “Max Power” setting for the access points (14) and selecting a more appropriate value for the access list (signal -67..120 for “Accept”), it’s working fine. There are still occasional outages, but they’re not as frequent anymore. There are no outages by CAP AXs, only by CAP ACs, but the frequency of the outages is now tolerable.
My understanding was to not use the access-list signal accept range when using FT, as the mechanisms would fight each other. FT in fact measures signal of current and adjacent APs and makes the smarter decision on when to transition. Having an AP disconnect a client based on going below -67 would probably cause outages.
When I was testing FT, I didn't use an access list for the signal. FT doesn't work well on my CAP ACs with the wifi-qcom-ac. That's why I'm using the solution recommended in the post above. I turned off FT, and then I have to use access lists for the signal.
Believe me, I've spent a lot of time trying out different tests, and this one works best for me.
FT just accelerates authentication to the new AP when roaming. It has nothing to do with signal strength or AP selection. Whenever FT is involved, the client will already have made the decision to roam and had already selected a new AP.
Kicking off clients with low signal strength via access list will never help seamless roaming; doing this will always cause interruptions. Seamless roaming can only work if the client decides to roam.
