Roaming/FT na WAP AX
I have problem with wifi clients roaming from CAP AC (wifi-q-com-ac) to WAP AX and also from WAP AX to WAP AX. There is problem with the clients by roaming, they are disconnected for 5-10 second at near 50% of test. Tested by different client divices, with long term and stable firmware. I use new CAPSMAN with config from official Mikrotik docs - with /interface wifi security ft=yes ft-over-ds=yes. I tried 2.4 Ghz, 5Ghz, with steatring, without stearing. No successs. Has anybody met any problems on WAP AX and roaming?
No export, no configuration information provided.
As indicated, you may have to provide a bit more details on current config.
Which versions did you try ? You don't tell.
EDIT: just saw your exports. Fixed code blocks and removed serials.
wap-ax:
# 2026-10-20 09:31:24 by RouterOS 7.23.8
# software id = RE77-GG9U
# model = wAPG-5HaxD2HaxD
# serial number = REMOVED
add name=bridge1 vlan-filtering=yes
/interface wifi datapath
add bridge=bridge1 disabled=no name=datapath1
/interface wifi
# managed by CAPsMAN 172.27.255.2, traffic processing on CAP
# mode: AP, SSID: PENTA, channel: 2437/ax
set \[ find default-name=wifi1 \] configuration.manager=capsman .mode=ap
datapath=datapath1 datapath.vlan-id=1 disabled=no
/snmp community
add addresses=172.27.4.11/32 name=x
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=4
/interface wifi cap
set caps-man-addresses=172.27.255.2 enabled=yes slaves-datapath=datapath1
add address=172.27.12.64/16 interface=bridge1 network=172.27.0.0
set servers=172.27.1.1,172.27.4.1
/ip firewall service-port
set sip disabled=yes
add disabled=no dst-address=0.0.0.0/0 gateway=172.27.255.253 routing-table=
main
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set reverse-proxy disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=CAP-KAT-R09-0114
/system ntp client
set enabled=yes
/system ntp client servers
add address=172.27.1.1
/system package update
set channel=long-term
/system routerboard settings
set auto-upgrade=yes
CAPSMAN:
# 2026-10-29 14:51:48 by RouterOS 7.25
# software id = CIEX-9MID
# model = CCR2004-16G-2S+
/ipv6 settings
/interface wifi channel
add band=2ghz-n disabled=no frequency=2412 name=channel-2.4G-ch1 width=20mhz
add band=2ghz-n disabled=no frequency=2437 name=channel-2.4G-ch6 width=20mhz
add band=2ghz-n disabled=no frequency=2462 name=channel-2.4G-ch11 width=20mhz
add disabled=no frequency=5180 name=channel-5G-ch36 width=20mhz
add disabled=no frequency=5200 name=channel-5G-ch40 width=20mhz
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes name=
sec-PENTA passphrase=X
sec-PENTAHOSTE passphrase=J
/ip ssh
set host-key-type=rsa known-hosts-validation=no
/ip service
/interface wifi capsman
set enabled=yes interfaces=bridge1 package-path=/firmware
add bridge=bridge1 disabled=no name=datapath-VLAN1 vlan-id=1
add bridge=bridge1 disabled=no name=datapath-VLAN4 vlan-id=4
add bridge=bridge1 disabled=no name=datapath-AC
add address=172.27.255.2/16 interface=bridge1 network=172.27.0.0
main
/system clock
/system identity
set name=CAPSMAN01
/system ntp client
set enabled=yes
set enter-setup-on=delete-key
/interface wifi configuration
add channel=channel-2.4G-ch1 country=Czech datapath=datapath-VLAN1 disabled=
no installation=indoor name=cfg-PENTA-2.4G-ch1 security=sec-PENTA ssid=
PENTA
add channel=channel-2.4G-ch1 country=Czech datapath=datapath-AC disabled=no
installation=indoor name=cfg-PENTA-2.4G-ch1-AC security=sec-PENTA ssid=
PENTA
add channel=channel-2.4G-ch6 country=Czech datapath=datapath-VLAN1 disabled=
no installation=indoor name=cfg-PENTA-2.4G-ch6 security=sec-PENTA ssid=
PENTA
add channel=channel-2.4G-ch6 country=Czech datapath=datapath-AC disabled=no
installation=indoor name=cfg-PENTA-2.4G-ch6-AC security=sec-PENTA ssid=
PENTA
add channel=channel-2.4G-ch11 country=Czech datapath=datapath-VLAN1 disabled=
no installation=indoor name=cfg-PENTA-2.4G-ch11 security=sec-PENTA ssid=
PENTA
add channel=channel-2.4G-ch11 country=Czech datapath=datapath-AC disabled=no
installation=indoor name=cfg-PENTA-2.4G-ch11-AC security=sec-PENTA ssid=
PENTA
add country=Czech datapath=datapath-VLAN4 disabled=no installation=indoor
name=cfg-PENTAHOSTE security=sec-PENTAHOSTE ssid=PENTAHOSTE tx-power=12
add country=Czech datapath=datapath-AC disabled=no installation=indoor name=
cfg-PENTAHOSTE-AC security=sec-PENTAHOSTE ssid=PENTAHOSTE tx-power=12
no installation=indoor name=cfg-PENTA-2.4G-ch6-WAP security=sec-PENTA
ssid=PENTA
no installation=indoor name=cfg-PENTA-2.4G-ch11-WAP security=sec-PENTA
ssid=PENTA
no installation=indoor name=cfg-PENTA-2.4G-ch1-WAP security=sec-PENTA
ssid=PENTA
add channel=channel-5G-ch36 country=Czech datapath=datapath-AC disabled=no
installation=indoor name=cfg-PENTA-5G-ch36 security=sec-PENTA ssid=PENTA2
add channel=channel-5G-ch40 country=Czech datapath=datapath-AC disabled=no
installation=indoor name=cfg-PENTA-5G-ch40 security=sec-PENTA ssid=PENTA2
/interface wifi provisioning
add action=create-dynamic-enabled comment=CAP-KAT-R04-0101-Prodej-2.4
disabled=no master-configuration=cfg-PENTA-2.4G-ch1-AC name-format=%I-%r
radio-mac=CC:2D:E0:ED:21:07 slave-configurations=cfg-PENTAHOSTE-AC
slave-name-format=%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R04-0102-Uctarna-2.4
radio-mac=CC:2D:E0:EA:62:10 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R04-0103-IT-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch6-AC name-format=%I-%r radio-mac=
CC:2D:E0:EA:62:04 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R04-0103-IT-5 disabled=no
master-configuration=cfg-PENTA-5G-ch40 name-format=%I-%r radio-mac=
CC:2D:E0:EA:62:05 slave-name-format=%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R04-0104-Zasedacka-2.4
disabled=no master-configuration=cfg-PENTA-2.4G-ch11-AC name-format=%I-%r
radio-mac=CC:2D:E0:EA:46:46 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R04-0106-Reklamace-2.4
disabled=no master-configuration=cfg-PENTA-2.4G-ch6-AC name-format=%I-%r
radio-mac=78:9A:18:41:4A:E3 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R04-0107-Kuchyne-2.4
radio-mac=D4:01:C3:69:C9:9E slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0101-2.4 disabled=no
CC:2D:E0:EA:61:98 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0102-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch1-AC name-format=%I-%r radio-mac=
CC:2D:E0:EA:61:C4 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0103-2.4 disabled=no
CC:2D:E0:EA:61:88 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0104-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch11-AC name-format=%I-%r radio-mac=
CC:2D:E0:EA:62:08 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0105-2.4 disabled=no
CC:2D:E0:EA:61:9C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0106-2.4 disabled=no
CC:2D:E0:EA:45:BE slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0107-2.4 disabled=no
CC:2D:E0:EA:62:00 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0108-2.4 disabled=no
CC:2D:E0:EA:46:BE slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0109-2.4 disabled=no
CC:2D:E0:EA:61:A8 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0110-2.4 disabled=no
CC:2D:E0:EA:46:D6 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0111-2.4 disabled=no
CC:2D:E0:EA:62:14 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0112-2.4 disabled=no
CC:2D:E0:EA:61:E0 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0113-2.4 disabled=no
CC:2D:E0:EA:46:66 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0114-2.4 disabled=no
18:FD:74:F8:1B:42 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0115-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch6-WAP name-format=%I-%r radio-mac=
D0:EA:11:D5:87:CD slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v supported-bands=2ghz-n
add action=create-dynamic-enabled comment=CAP-KAT-R11-0101-5 disabled=no
master-configuration=cfg-PENTA-5G-ch36 name-format=%I-%r radio-mac=
D0:EA:11:BA:DB:38 slave-name-format=%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R06-0116-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch1 name-format=%I-%r radio-mac=
38:32:7A:32:A6:8C slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R06-0117-2.4 disabled=no
18:FD:74:63:A7:20 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0118-2.4 disabled=no
18:FD:74:63:A8:1C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0118-5 disabled=no
18:FD:74:63:A8:1D slave-name-format=%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R16-01test-5 disabled=no
18:FD:74:F9:A4:59 slave-name-format=%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R06-0119-2.4 disabled=no
D4:01:C3:63:10:3E slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R06-0122-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch11-WAP name-format=%I-%r radio-mac=
D0:EA:11:D5:87:D7 slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R07-0116-2.4 disabled=no
2C:C8:1B:5C:FC:AD slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0101-2.4 disabled=no
2C:C8:1B:5C:FD:A1 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0102-2.4 disabled=no
2C:C8:1B:5C:FE:79 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0103-2.4 disabled=no
08:55:31:F9:27:2F slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0104-2.4 disabled=no
2C:C8:1B:5C:FD:87 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0105-2.4 disabled=no
2C:C8:1B:5C:FE:3F slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0106-2.4 disabled=no
2C:C8:1B:5C:FE:49 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0107-2.4 disabled=no
2C:C8:1B:5C:FE:B5 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0108-2.4 disabled=no
2C:C8:1B:5C:FC:6D slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0109-2.4 disabled=no
2C:C8:1B:5C:FC:97 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0110-2.4 disabled=no
2C:C8:1B:5C:FE:EB slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0111-2.4 disabled=no
2C:C8:1B:5C:FE:BB slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0112-2.4 disabled=no
2C:C8:1B:5C:FE:33 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0113-2.4 disabled=no
2C:C8:1B:5C:FC:9B slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0114-2.4 disabled=no
2C:C8:1B:5C:FE:37 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0115-2.4 disabled=no
2C:C8:1B:5C:FE:05 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0117-2.4 disabled=no
2C:C8:1B:5C:FC:A9 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0118-2.4 disabled=no
2C:C8:1B:5C:FC:A5 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0119-2.4 disabled=no
2C:C8:1B:5C:FE:6D slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0120-2.4 disabled=no
2C:C8:1B:5D:03:2B slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R07-0121-2.4 disabled=no
2C:C8:1B:5C:FE:09 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0101-2.4 disabled=no
2C:C8:1B:36:5E:6C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0102-2.4 disabled=no
2C:C8:1B:30:ED:8F slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0103-2.4 disabled=no
2C:C8:1B:32:36:9A slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0104-2.4 disabled=no
2C:C8:1B:30:7D:48 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0105-2.4 disabled=no
2C:C8:1B:36:5C:0E slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0106-2.4 disabled=no
2C:C8:1B:36:4B:89 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0107-2.4 disabled=no
2C:C8:1B:36:52:7C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0108-2.4 disabled=no
D4:01:C3:63:17:B4 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0109-2.4 disabled=no
2C:C8:1B:30:7D:30 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0110-2.4 disabled=no
2C:C8:1B:36:5F:A5 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0111-2.4 disabled=no
2C:C8:1B:36:5D:88 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0112-2.4 disabled=no
2C:C8:1B:36:5D:AD slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0113-2.4 disabled=no
2C:C8:1B:36:4E:A0 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0114-2.4 disabled=no
2C:C8:1B:36:54:3F slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0115-2.4 disabled=no
2C:C8:1B:32:36:08 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0116-2.4 disabled=no
2C:C8:1B:36:5A:53 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0117-2.4 disabled=no
2C:C8:1B:36:4E:6C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0118-2.4 disabled=no
2C:C8:1B:36:5D:2B slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0119-2.4 disabled=no
2C:C8:1B:32:2F:4A slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0120-2.4 disabled=no
2C:C8:1B:36:59:13 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0121-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch1-WAP name-format=%I-%r radio-mac=
D0:EA:11:98:BC:71 slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R08-0122-2.4 disabled=no
D0:EA:11:97:C3:F8 slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R08-0123-2.4 disabled=no
48:A9:8A:1F:8B:A0 slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0124-2.4 disabled=no
48:A9:8A:1F:8B:6C slave-configurations=cfg-PENTAHOSTE-AC
add action=create-dynamic-enabled comment=CAP-KAT-R08-0125-2.4 disabled=no
D0:EA:11:98:E8:CE slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R08-0126-2.4 disabled=no
D0:EA:11:98:E8:C5 slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R08-0127-2.4 disabled=no
D0:EA:11:98:B8:15 slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R08-0128-2.4 disabled=no
D0:EA:11:98:E7:5F slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled comment=CAP-KAT-R10-0101-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch11 name-format=%I-%r radio-mac=
D0:EA:11:BB:1F:9B slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0102-2.4 disabled=no
D0:EA:11:40:DA:F0 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0103-2.4 disabled=no
master-configuration=cfg-PENTA-2.4G-ch6 name-format=%I-%r radio-mac=
D0:EA:11:40:C8:F3 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0104-2.4 disabled=no
D0:EA:11:BB:1F:F3 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0105-2.4 disabled=no
D0:EA:11:BB:1F:7F slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0106-2.4 disabled=no
D0:EA:11:BB:1F:9F slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0107-2.4 disabled=no
D0:EA:11:BB:1F:2B slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0108-2.4 disabled=no
D0:EA:11:BB:1F:23 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0109-2.4 disabled=no
D0:EA:11:BB:1F:AF slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R10-0110-2.4 disabled=no
D0:EA:11:BB:1F:43 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0102-2.4 disabled=no
D0:EA:11:BB:1F:B3 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0101-2.4 disabled=no
D0:EA:11:BB:1F:73 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0103-2.4 disabled=no
D0:EA:11:BB:1F:13 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0104-2.4 disabled=no
D0:EA:11:BB:1E:F7 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0105-2.4 disabled=no
D0:EA:11:BB:1F:2F slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0106-2.4 disabled=no
D0:EA:11:C0:35:95 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0107-2.4 disabled=no
D0:EA:11:C0:44:E4 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0108-2.4 disabled=no
D0:EA:11:C0:78:77 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0109-2.4 disabled=no
D0:EA:11:C0:75:67 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0110-2.4 disabled=no
D0:EA:11:C0:84:B5 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0111-2.4 disabled=no
D0:EA:11:C0:84:88 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0112-2.4 disabled=no
D0:EA:11:BB:14:EF slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0113-2.4 disabled=no
D0:EA:11:BB:1F:C3 slave-configurations=cfg-PENTAHOSTE slave-name-format=
%m%v
add action=create-dynamic-enabled comment=CAP-KAT-R09-0114-2.4 disabled=no
D0:EA:11:98:B5:DC slave-configurations=cfg-PENTAHOSTE slave-name-format=
add action=create-dynamic-enabled disabled=no master-configuration=
cfg-PENTA-2.4G-ch6-AC name-format=bubuub slave-configurations=
cfg-PENTAHOSTE-AC
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 tagged=sfp-sfpplus2,ether16 vlan-ids=4
Test ted with Zebra MC3300, different andriod new mobile phones as clients.
CAP-AC:
# 2026-10-14 14:44:07 by RouterOS 7.23.8
# software id = XP36-R9LB
# model = RBcAPGi-5acD2nD
/interface wifi
# mode: AP, SSID: PENTA, channel: 2412/n
disabled=no
# mode: AP, SSID: PENTAHOSTE
add disabled=no mac-address=CE:2D:E0:EA:62:10 master-interface=wifi1 name=
wifi3
/snmp community
add bridge=bridge1 interface=wifi1
add bridge=bridge1 interface=wifi3 pvid=4
/ipv6 settings
add bridge=bridge1 tagged=ether1 untagged=wifi3 vlan-ids=4
/interface wifi cap
set caps-man-addresses=172.27.255.2 enabled=yes slaves-static=yes
add address=172.27.12.2/16 interface=bridge1 network=172.27.0.0
main
/ip service
/snmp
set enabled=yes
/system clock
/system identity
set name=CAP-KAT-R04-0102-Uctarna
/system ntp client
set enabled=yes
Tested with logn term 7.23.8 and stable 7.25 on CAPSMAN and CAPS.
For me that wap AX is not configured correctly.
You only need to specify capsman as manager and datapath for wifi interface, nothing else.
Did you have a look at the examples in Manual pages ?
CAP using "wifi-qcom" package
/interface/bridge
add name=bridgeLocal
/interface/wifi/datapath
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface/wifi
set [ find default-name=wifi1 ] configuration.manager=capsman datapath=capdp disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman datapath=capdp disabled=no
/interface/bridge/port
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
/interface/wifi/cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
/ip/dhcp-client
add interface=bridgeLocal disabled=no
I stopped reading when I saw the mix and match of AC and AX.
Do you mean that AC and AX cannot work well together?
I tested it before in "a laboratory" with two CAP ACs a nd one WAP AX and it was O.K. But now I have 60 CAP AC, 9 WAP AX and 14 CAP AX and it all works very bad. The client sees min. 1 AP with a distance max 15m at each time. I used old CAPSMAN with same CAP ACs with access list and roaming was O.K. in the past. We have bought new CAP AX and WAP AX for new rooms....
Of course, I started with Router OS manuals and examples. The config lines in my configs as SNMP, IP services have nothing to do with the function of wifi. I sent real complete configs. I hope that none of them can break function of AP.
I have always had problems with roaming and general connections with multiple vendors, when I mixed ACv1 and ACv2. It was worse when I tried to mix AC and AX.
Forget about how differently Mikrotik handels VLANs between the 2.
I have capsman managed hap ac2 (wifi-qcom-ac) mixed with hap ax2 (wifi-qcom) and I get the best roaming experience with
  • WPA2-PSK only
  • Protected management frames disabled
  • FT and FT-over-DS disabled(!)
  • Connect-priority=0/1
Reasoning:
WPA3 and/or PMF sometimes leads to disconnects during roaming, especially on my hap ax2. May be a bug, maybe bad client behavior. Just keep it disabled if possible.
WPA2-PSK authentication is fast enough that FT brings little benefit. Keeping FT disabled avoids recent bugs (see ROS 7.25 changelog). FT-over-DS is a bad idea anyways.
Connect priority 0/1 setting allows a client to connect to a new AP without explicitly disconnecting from the previous one. This improves roaming by sacrificing protection from MAC address cloning. I would always set this in a trusted network.
Thank you very much for your help. I’ve tried it out. I must say, there has been a significant improvement.
Your settings:
add authentication-types=wpa2-psk connect-priority=0/1 disable-pmkid=yes disabled=no ft=no ft-over-ds=no name=sec1 passphrase=X
is for my situation much better than the settings from RouterOS Manual:
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes name=sec1 passphrase=X
It is much better but there are still Wi-Fi connection dropouts during roaming.
I tried it with pure network by CAP AXs and there were no dropouts. Second test was in pure network by CAP ACs and there were some dropouts. I think that CAP ACs have any problems by wifi-qcom-ac package with roaming.
We use our Wi-Fi network in the warehouse, where warehouse workers are constantly on the move around with Wi-Fi terminals and outages are a major issue for us . We don't require a high bandwidth (we use Remote Desktop clients), but we do need the reliable roaming. May be that our APs are too close and the wifi client sees too many of them in one time. I know, that there are issues here with the APs interfering with each other—when using channels 1, 6, and 11, there are only three options I can assign to the APs, but I need complete coverage of the warehouse, so I have to use more APs there, even if it means they interfere with each other.
It tried to reduce TX Power without much improvement. I think that we have to decide if we will replace new CAP AXs to CAP ACs and move back to wireless package with old Capsman with the Access lists or replace all CAP ACs with CAP AXs.
How many devices show as ft-wpa2-psk in wifi/registration when ft is on? Those will definitely benefit from ft . . . if few or none, off might be a good call. Myself, I also have the connect priority 0/1 set, but no ac devices either, and it seemed to help. ft devices are seamless, and no gripes about the others either.
I also use fixed frequencies spread out to avoid interference (including DFS channels, since there is no radar in the area).
I have about 20 devices using FT-WPA2-PSK and 4 devices using WPA2-PSK (older Wi-Fi devices) when FT is enabled. I tested this on the 2.4 GHz with many CAP AC access points, as well as on the 5 GHz with 3 access points on different channels. The problem with the CAP AC access points is the same for both —there are frequent disconnections lasting 5–10 seconds due to roaming. I suspect that the CAP AC access points have some issues with the wifi-qcom-ac package related to roaming.
I also control a warehouse setup with MC9200 scanners.
Capsman on RB5009 but only cap ax and hap ax3 devices.
No AC.
No problems.
How many cap ax's do you have and how big is the warehouse if thats okay to state, purely out of curiousity, its fine if you cant disclose that.
Also why hap ax3 and not just fully cap ax?
9x cAP AX in warehouse (ceiling varying from 5m to 6m height)
6x hAP AX3 in warehouse, office spaces and adjacent shop.
One hAP AX3 because I needed to extend an antenna to outside to cover a bunker with highly flammable liquids (scanners can go in there, other equipment not). cAP AX can not be placed outside so at the time, that was the solution since there wasn't wAP AX yet then. I probably will replace that setup, someday/maybe.
Another AX3 placed on top of a network cabinet to cover a blind spot which appeared after re-organization of some storage racks.
3x AX3 in office spaces for wifi and added ethernet ports.
1x AX3 in shop which is adjacent to warehouse (ceiling too low and couldn't use cAP AX to cover the complete shop, I tested it on various locations).
Total warehouse space is a bit less then 4000m2 (incl. about 500m2 for all office spaces, 2 floors).
