I have a rb1009 directly connected to a ubnt Litebeam ACgen2 connected to an other Litebeam ACgen2. Neighbors can see some of the hAP and Mikrotik POE switches. When i ROMON it to the rb1009 nothing shows up.
“deltamc2000” your sollution is working but is not permament. if you reboot the unifi switch the configuration is lost and no romon again. is there any way for permanent sollution?
it is a MUST. i can access remotely behind main router all my mikrotik switches and access points by just enabling romon in each device. simple as that. nothing else to configure. thank u mikrotik for that.
there is a nice article below. ( i dont advertise)
“You can not only discover these devices, you can also ping them, SSH to them, and connect to them with Winbox – without the need for tunnels, NAT or special routing rules.”
A must is something that can not be done in any other way… So am sure ROMON is not…
The fact that you can only achieve it with the use of ROMON because you might not know another way is something else …
If you give more details, a network diagram with the IP addresses etc we can help you make the routing work…
