It seems ROS3 does not perform well at all on the RB100 series boards. CPU loads consistently spike to 100%, and seems to effect performance. Is this something you’re (mikrotik) working on and aware of? Or are these boards going to be replaced with RB400 series, with more capable hardware?
I no longer order the RB133c’s, replaced with RB411’s.. unfortunately theres no replacement for the RB133 yet, unless you go to the RB333 which has a significant price jump.
I see the spikes with idle equipment sitting on a bench, with no interfaces connected, aside from the ethernet. No services being polled/monitored by dude. Spikes seen in winbox, not sure if they exist when connecting via SSH/telnet. I’ll look into that and reply back.
Packages installed:
Advanced-Tools
CLEA
DHCP
PPP
Routing
System
Wireless
NTP
ROS V.3.xx (happens on all up to the current release 3.4)
Somewhere on this forum is explained the difference in ros 2.9 and 3.x I don´t know anymore where but what I remember is that it comes down to the cpu monitoring time lapse. In 3.x it is more precise than in 2.9. It monitors in shorter time lapse.
Every cpu has spikes of 100%. Actually, all activity happens at 100% of the cpu’s capacity. If it is only a very small task it only takes such little time the monitor that calculate the usage over some time calculate a low usage. The shorter this monitor’s ´time-lapse` is, the higher a cpu load for a certain activity.
What is really important to see is the average usage over a somewhat longer period of time. Let say some minutes or more. The longer the monitor show a higher usage level the heavier the load is. As long as you do not see a consistent (5 mins, 10 mins or longer) higher then 60-70% cpu usage the cpu is fine and just doing what it is made for.
Compare it with your CPU load of your Windows or Linux PC. Go to task manager and see what the CPU of your PC is doing. You will high loads of it when you run a video, calculate big spreadsheets or compress a big file. Both is loads of work and the processor has to ´work´. But simple tasks as opening a simple text file still creates a ´spike´ of almost 100%, but only for a very short time. An even simpler taks would even create a 100% spike but will be so short in time the cpu usage graph doesn´t even show it anymore, or only with 10 or 20% or so.
I don´t think rb133c’s are going to be replaced soon, they are just on the market for a year or so and they function perfect as client CPU with firewall and mangle rules in place on 3Mb links and with ros3.x and are relative cheap.
I have 50 of these running and general cpu usage shows 10-30% cpu load, with the spikes of 100%
Bottom line, if nothing special went wrong and the rb100 series boards are working normal spikes of 100% are nothing to worry about.
In the RB150 seems not to be a normal issue, it crash the ROS… I´m not talking about CPU spikes, I´m talking about crash… the config? 1 Bridge, with ether1,ether2,ether3,ether4,ether5… I used as a switch…
The ROS CRASH !! not just spikes of CPU…
Regarding upgrade from 2.9.x family to 3.x some issues are shown on this forum. Some of these should be cleared in 3.4 according the change log. Read this forum. There are several treads about cards crashing after the upgrade and in some cases solutions are given, some cases also see the cards being returned to the supplier/MT.
Also, what do you mean with a ´crash´? There are several different problems that can happen people refer to as a ´crash´ and so there are several solutions (or none if not) related to the type of crash.
But the crashes are still a small minority. And they happen on almost any type of boards. Lots of boards have been upgraded under the same circumstances as the failing ones. Some crashed, most not.
If the winbox program is crashing try removing all of the mikrotik related files in %userprofile%\Application Data\ folder.. delete winbox.exe and redownload from your router.. ROS 3.xx uses a newer version of winbox.
If the router itself is crashing, i’d reinstall ROS via netinstall.
WirelessRudy – I have a device sitting idle doing nothing. There should be no reason why it consistently spikes to 100% load every few seconds.
Literally has no configuration, did a Netinstall and logged in. I’ll do some further testing today and reply back. I want to know if this is effecting performance as well.
William,
How do you see the CPU ´spikes´? This is some CPU routine just doing this… so here is your little activity!
And just the way you monitor your routerboard is already creating some activity from the CPU as well. Here´s another source… If the CPU would really rate 0% for a long time I would consider it to be dead! (How can you monitor a CPU that is dead? By showing some ´spikes´ it at least tells you its healthy!
And believe me, when the 100% spikes only happen irregular and occasionally, some high spikes every two or three, four minustes, it is very normal. My P5 with 1Mb internal is always showing some 100% spikes, even if there is really no traffic so he really has nothing to do then showing me that he is ´alive´.
unfortunately I have the same problem, CPEs based on RB133c easly jump to 100% CPU usage.
Using the device directly connected to the PC for configuration settings (no snmp, no ping, no traffic on interfaces), it simply crashes when I try to do en export command. E.G. “[CPE_RB133c]>exprt file=test”, results in a crash: CPU usage stops at 100% and (after 10-20sec.) WinBox disconnects.
If same command is executed in Telnet mode (with no WinBox active), problem doesn’t accour. This is evidence that CPU resources are not enough, hope that new RB411 gives better results…
This is a great problem because, working on CPEs already installed at Customer’s site, 100% CPU usage means disconnection from wireless network…
cpresto,
It sounds to me you have another problem.
I have 10 rb112 CPE’s and 57 rb113c’s CPE all running now versions 3,0 or 3,2 or 3,4 in a production environment. None of these is crashing and none of these see long time spans (in secs) of high CPU usage. They all have firewall filters running and traffic over them runs as 3Mb max. and even then low CPU usage. I don´t see what is wrong with these recent desiged boards (rb133). They perform fine.
I really think you have a problem of a different kind, suggest you send a mail to support or ask on this forum if anyone can help you.
This is stupid bug.
All day RB411 has cpu on 100%. Why ? Because its monitored by Dude.
I disabled all services but ping and rb is running smoothly now.
Some of RB133 have similar problem i have 2 of them.
you can configure it after reinstall but after very quick time they are unusable!
symptoms are like described above (100% cpu, winbox-terminal crashes).
i dont know does rb were monitored by dude when these problems ocured.
worth trying.
as described in my post, RB133c was not connetd only to my PC, so no ping, Dude or whatelse where running…Looking around the forum, this seems to be a known problem.
I think that is not true. It proves something else is wrong, config, bad cable connection or anything else. The CPU power of the rb133c’s is sufficiant to all the things you try to do at ease. It could also be you have a board that is not OK. In that case you should contact your supplier for an rma.
Like said, MT is probably selling the rb133c’s by the thousands and so far I see only two guys on this forum complaining about the CPU and to readers it is not even clear what they exactly want… or see…
There are guys running hundreds of these boards in production. I do about 60 of them and we have no problems with the CPU power. It spikes sometimes to 100% but that is to be expected and very normal…
On average the CPU’s work at 10-30% of the cpu capacity under full load circumstances (3Mb traffic with firewalls, natting and routing. ) I can move files in and out the CPE at 20Mb, I can run an export, all little load on the CPU.
Rudy
We have a mesh with 9 RB112s. Working fine for six months on 2.9.xx . We upgraded all to 3.3 and now 4 of them have crashed inside 2 days. CPU stays on 100% and I cannot see anything in winbox or terminal.
I only installed the following packages: routerboard, system, wireless, NTP, routing, security.
We have Dude running but I have turned off polling on this network to see if that helps.
Well I though that only I who got the problem.. I have RB133c with ROS 3.xx, not just
the CPU became 100%, the booting is taking soo long, even became fail then restart..
