for my expanding network,i research WDS dynamic mesh mode, why when i use ROS 5.22 my WDS network can’t connect? it’s a bug?
when i use ROS 5.14 it’s work correctly
I run my RB411GL’s and Omnitik’s on ROS 5.22 using dynamic-mesh and everything works great.
Whats your configuration?
Today i tried connect two OmniTik`s with MESH, and i am not satisfied…
550 meters (with google maps), dual chain A/N 20/40mhz and only !ONE! Mbit works.
Signal on both of them is about -72 - this is normal?
Devices on this same height, clean terrain / visibility 100%
if only 2 node,i think it’s not mesh,just PtP CMIIW,
my network diagram like this :
this is result btest from a node in my network
but it run in dynamic WDS-mode, not dynamic-mesh
I want to connect more of this devices, test was on two only…
