ros 7.1.1 hotspot clients not reachable to gateway
I migrated from v6.48 to v7.1.1, all firewall conf keeps same, everything works well except hostspot. Clients can connect to hotspot and access internet at first few minutes, after that, client couldn’t ping gateway although wifi connection wasn’t lost.
This is a know issue at MT, I’m still waiting for them to fix it too
thanks for the info.I took one day on it and I will wait for next release.
I upgraded to 7.1.2 and still same. And I lost some vlan config so had to restore my backup
exactly same behavior on my side (tested also with ROS 7.2rc3)
I also opened a ticket at mikrotik - no solution till now.
It could also be the same topic as here: http://forum.mikrotik.com/t/hotspot-login-page-disconnect-after-while/154813/3
By the way - I disabled hotspot service (so it is a basic router) and everything works fine and stable - so it has to be an issue with the hotspot package.
It is not solved - please adjust topic!
same… already sent a ticket but until now they didn’t fix this issue.
i have this problem too and they haven’t acknowledge the issue :frowning:
same here
captive portal is reachable from normal network but not from the one i use for hotspot
… no response from Mikrotik until now! (Ticket is also unanswered for almost 14 days)…
Please help.
Did they solve the problem? I have the same problem, after a few seconds the PING does not even go to the router. Without HOTSPOT everything is OK. I’ll try it for a few days now and I’ve come across this fiber. :frowning:
7.2.3 and the problem persists
Seems to be solved in 7.4 Beta 4 or 5
