Just to add to this. I have setup a GNS3 lab for this, to take the testing off the live environment.
If I add a vyos 1.4 (basically FRR 8.5.2) to the mix, I get a similar error vyos side
Nov 23 06:03:28 ospfd[870]: [S5PCG-77H23] Packet[DD]: Neighbor 10.0.1.1 Negotiation done (Master).
Nov 23 06:03:28 ospfd[870]: [W5JSG-1RC06][EC 134217741] LSA[Type10:1.0.0.0] from 10.0.1.1: Opaque capability mismatch?
Nov 23 06:03:33 ospfd[870]: [S5PCG-77H23] Packet[DD]: Neighbor 10.0.1.1 Negotiation done (Master).
Nov 23 06:03:33 ospfd[870]: [W5JSG-1RC06][EC 134217741] LSA[Type10:1.0.0.0] from 10.0.1.1: Opaque capability mismatch?
Nov 23 06:03:38 ospfd[870]: [S5PCG-77H23] Packet[DD]: Neighbor 10.0.1.1 Negotiation done (Master).
Nov 23 06:03:38 ospfd[870]: [W5JSG-1RC06][EC 134217741] LSA[Type10:1.0.0.0] from 10.0.1.1: Opaque capability mismatch?
Nov 23 06:03:43 ospfd[870]: [S5PCG-77H23] Packet[DD]: Neighbor 10.0.1.1 Negotiation done (Master).
Nov 23 06:03:43 ospfd[870]: [W5JSG-1RC06][EC 134217741] LSA[Type10:1.0.0.0] from 10.0.1.1: Opaque capability mismatch?
Nov 23 06:03:48 ospfd[870]: [S5PCG-77H23] Packet[DD]: Neighbor 10.0.1.1 Negotiation done (Master).
Nov 23 06:03:48 ospfd[870]: [W5JSG-1RC06][EC 134217741] LSA[Type10:1.0.0.0] from 10.0.1.1: Opaque capability mismatch?
Nov 23 06:03:48 ospfd[870]: [G51J2-0949Y][EC 134217741] Packet[DD]: Neighbor 10.0.1.1 Negotiation fails.
Seems like ROS 7 is not correctly implementing opaque areas. Perhaps we need an option under the instance or interface-template to enable opaque lsa’s?
From the vyos’s ospf neighbor perspective.
R-ID: 10.0.1.1 is ROS7
R-ID: 10.0.1.2 is EOS
vyos# sh ip ospf neighbor detail
Neighbor 10.0.1.1, interface address 10.0.0.1
In the area 0.0.0.0 via interface eth0
Neighbor priority is 0, State is ExStart/DROther, 498 state changes
Most recent state change statistics:
Progressive change 1.014s ago
Regressive change 1.012s ago, due to SeqNumberMismatch
DR is 10.0.0.3, BDR is 10.0.0.2
***** Options 2 *|-|-|-|-|-|E|-
Dead timer due in 39.621s
Database Summary List 0
Link State Request List 0
Link State Retransmission List 0
Thread Inactivity Timer on
Thread Database Description Retransmision on
Thread Link State Request Retransmission off
Thread Link State Update Retransmission off
Graceful restart Helper info:
Graceful Restart HELPER Status : None
Neighbor 10.0.1.2, interface address 10.0.0.2
Neighbor priority is 1, State is Full/Backup, 14 state changes
Progressive change 5m46s ago
Regressive change 5m50s ago, due to 1-WayReceived
****** Options 66 *|O|-|-|-|-|E|-
Dead timer due in 39.833s
Thread Database Description Retransmision off
Thread Link State Update Retransmission on
I will add a ROS6 to the bench and update the post
This problem has been resolved in RouterOS 7.12 and newer.
The pace of development for RouterOS v7 is very fast, so it is important that you post the exact version of RouterOS v7 that you are running to make it easier for people to help you.
[admin@MikroTik] > system/package/print
Columns: NAME, VERSION
# NAME VERSION
0 routeros 7.12.1
Arista still reporting issues
1:OSPF Recv: Opaque LSA from neighbor that did not set the opaque option, id 1.0.0.2 advrt 10.0.1.1
Same with the vyos
vyos@vyos:~$ show ip ospf neighbor detail
Neighbor priority is 0, State is ExStart/DROther, 15 state changes
Progressive change 4.692s ago
Regressive change 4.691s ago, due to SeqNumberMismatch
DR is 10.0.0.2, BDR is 10.0.0.3
Dead timer due in 30.333s
Neighbor priority is 1, State is Full/DR, 6 state changes
Progressive change 33.686s ago
Dead timer due in 35.299s
Thread Link State Request Retransmission on
