Got the RDS2216, it works well, but why in the world does the “Files” menu show every single file on the storage side of the house, as in every single file in every single sub-directory, instead of showing only the content of the current directory, and allow the user to browse directories? Once you start using it and you have tens of thousands of files on the router, it renders the Files menu essentially useless, and it creates lag and issues with your browser. And if you create a backup config from the Files menu, only way to find it is to sort files by “Last modified” date.
I get the fact that before ROSE, RouterOS was not a fileserver per se, but now that you’re in the storage/NAS business, why can’t you adopt the same logic as every single OS out there, i.e. only show the content of the current directory, and allow the user to browse sub-directories? It would make the Files menu a lot more user-friendly.
RouterOS originally did not have a fully featured file browser or even directory support, but this is now changing with all kinds of improvements being made every release. 7.20 will already have a much faster and more familiar Files menu
Good timing, glad to hear things are going to improve. I’m using the Files menu with a USB drive for various scripts, and quickly ran into the same challenges with thousands of files. The upcoming improvements should benefit even non-ROSE users.
Happy to hear this! I'm using ROSE on an X86 setup. It's super slow to show the files (over 350 000) and I can't even see those in the root. Kinda hard to retore a backup. At least I see them in CLI File-Print.
do you have tons a file in a single directory? and are you using winbox 4?
I was never able to open files section of winbox prior, but after upgrading to last beta of 7.20 with winbox 4, I no longer have an issue.
I’m talking about the files menu on the web interface. For reasons irrelevant to this thread, we do not use winbox. Kinda odd that they would fix winbox before fixing the UI on the router itself.
Yea i can confirm, web ui is still a miserable experience if you have a ton of files on the device. Winbox 4 and 7.20 seem to be the two things that make it usable at this point, hopefully they will follow up with fixes to web ui soon.
Revisiting this post. 7.20 as well as 7.21 came and went, and while they bring welcomed enhancements, the files menu is still the same, and on systems meant to host lots of files like RDS, it’s basically impossible to navigate.
