I'm trying to connect multiple hosts to a ROSE NVMe over TCP storage and tried to limit to those hosts via the Host-Based Access Control option.
Unfortunately, I could make it work only if one NQN is present in the field. I tried to put multiple NQN separated by comma, semi-colon, blank... and it does not work, the option is registered successfully but when I try to connect the storage to the hosts it fails.
Is it possible to put multiple NQN in the Host-Based Access Control field in the NVMe over TCP storage options?
Thanks for your answers!
