I have configured a NAT rule on the CHR (VPS) and tried the configuration last night, It worked. , And decided to go ahead with a fresh configuration once again as I am still learning and wanted to know what I’m exactly doing, But this time it didn’t go as planned, I may have missed out on something again.
Could establish a successful Ping to 10.0.1.1 and a Handshake.
Below Is the configuration:
CHR Configuration
/interface wireguard
add listen-port=13231 mtu=1420 name=WG-Server-BLR
add name=WAN
/port
set 0 name=serial0
add interface=ether1 list=WAN
add interface=WG-Server-BLR list=WAN
/interface wireguard peers
add allowed-address=10.0.1.2/32 interface=WG-Server-BLR name=RB5009-Home public-key="ABCDEFGHIJKLMNOPQ123456789"
add address=10.0.1.1/24 interface=WG-Server-BLR network=10.0.1.0
/ip dhcp-client
add action=accept chain=input connection-state=established,related,untracked \
connection-type=""
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
/system note
set show-at-login=no
RB5009 Configuration
add admin-mac=48:A9:8A:9F:B1:C0 auto-mac=no name=bridge
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no mac-address=\
5C:96:66:50:83:FA name=SFP-ODI-WAN rx-flow-control=auto \
sfp-shutdown-temperature=70C speed=1Gbps tx-flow-control=auto
set [ find default-name=ether1 ] mac-address=5C:96:66:50:83:FA
add listen-port=13231 mtu=1420 name=WG-Cloud-BLR
/interface vlan
add interface=SFP-ODI-WAN name=VL10-Broadband vlan-id=10
/interface pppoe-client
add add-default-route=yes disabled=no interface=VL10-Broadband name=\
Instanet-PPPoE-01 use-peer-dns=yes user=ISPUsername
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
"15 664 676 352" type=partition
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/routing table
add disabled=no fib name=ViaWG-Cloud-BLR
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge disabled=yes interface=ether1
/interface detect-internet
set detect-interface-list=all
add interface=Instanet-PPPoE-01 list=WAN
add interface=SFP-ODI-WAN list=WAN
add allowed-address=0.0.0.0/0 endpoint-address=129.XXX.XX.XX2 endpoint-port=\
13231 interface=WG-Cloud-BLR public-key=\
add address=192.168.1.10/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=192.168.2.10/24 interface=SFP-ODI-WAN network=192.168.2.0
add address=10.0.1.2/24 interface=WG-Cloud-BLR network=10.0.1.0
/ip arp
add address=192.168.2.1 interface=SFP-ODI-WAN
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.1.43 client-id=1:5c:96:66:50:83:fa mac-address=\
5C:96:66:50:83:FA server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.10 gateway=\
192.168.1.10 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.10 comment=defconf name=router.lan
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add disabled=no dst-address=129.XXX.XXX.XX0/32 gateway=Instanet-PPPoE-01 \
routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=Instanet-PPPoE-01 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10 vrf-interface=Instanet-PPPoE-01
add disabled=no dst-address=0.0.0.0/0 gateway=WG-Cloud-BLR routing-table=\
ViaWG-Cloud-BLR
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup comment="min-prefix=0 all known local routes go via main" \
disabled=no min-prefix=0 table=main
add action=lookup dst-address=0.0.0.0/0 src-address=192.168.1.43/32 table=\
ViaWG-Cloud-BLR
/system note
/tool mac-server
/tool mac-server mac-winbox
