Route extrn to intern
someone can say to tell me, to route a public IP to an internal Client IP ?
when I write in src-nat and dst-nat it is not work. Is the pransparent Web-Porxy the Probleme?
FW is 2.8.28
thx
dingsingo
hm, what exactly do you want to achieve ?
if you want to link Public address to local one (full NAT) check link:
http://www.mikrotik.com/docs/ros/2.8/howto/howto.content#12.2.6
in addition to adding the src/dst nat rules you have to add the public IP you’re mapping to the WAN interface on the router.
You mean so?
dst-nat:
1 X src-address=10.100.x.xx/32 action=masquerade to-src-address=216.2xx.xx.xx
and
src-nat:
1 X src-address=10.100.xx.xx/32 action=redirect to-dst-address=216.2xx.xx.xx
the Client become the 10.100.xx.xx/32 in his PPPoE-Data.
I think the Problem is, I’ve install more than an “main” Routingtable example : http://www.mikrotik.com/docs/ros/2.8/ip/route.content#7.48.4.4
dingsingo
no you dont use “action=masquerade” …
SRC-NAT
src-address=10.0.0.12/32 action=nat to-src-address=66.60.xx.xx
DST-NAT
dst-address=66.60.xx.xx/32 action=nat to-dst-address=10.0.0.12
IP Address
/ip address add 66.60.xx.yy/aa interface=wan
That will forward all requests from 66.60.xx.xx to 10.0.0.12 and vise-versa.
