Hello
I’m new to the whole mikrotik thing..
a simple question
I have a mikrotikOS which is a server for auth , etc , etc for L2TP users it does have access to Internet but i dont want to use it’s internet . so i have another server which is PPTP server that i want to use it’s internet for my users…
lets simplify it.
User --(use L2TP to connect to Mik)–> Mikrotik --(mikrotik use a pptp client to connect to pptp server )–> PPTP server
i have no idea how to do it..
so please help me step by step…
THX
I think you have a NAT rule in (/ IP firewall nat) that allows L2PT users to access to Internet.
It must be Masqueade. If need more help, plz tell me more about your configuration.
in terminal:
/ ip firewall nat print detail
/ ip route print detail
/ interface print detail
Copy these and send to me.
Hello and thx for your answer
here are what you wanted:
[admin@MikroTik] > /ip firewall nat print detail
0 chain=srcnat action=masquerade
[admin@MikroTik] > /ip route print detail
0 A S ;;; added by setup
dst-address=0.0.0.0/0 gateway=46.4.1xx.1
gateway-status=46.4.1xx.1 reachable WAN distance=1 scope=30
target-scope=10
1 ADC dst-address=46.4.1xx.0/26 pref-src=46.4.1xx.43 gateway=WAN
gateway-status=WAN reachable distance=0 scope=10
2 ADC dst-address=172.15.1.246/32 pref-src=172.20.1.1 gateway=<pptp-test>
gateway-status=<pptp-test> reachable distance=0 scope=10
[admin@MikroTik] > /interface print detail
0 R name="WAN" type="ether" mtu=1500
1 name="L2TP" type="l2tp-in"
2 X name="PPTPUS" type="pptp-out"
3 name="PPTP" type="pptp-in"
4 DR name="<pptp-test>" type="pptp-in" mtu=1400
As I think, it caused by your NAT rule. It can be done as below.
If you use winbox, It will be so easy. Go to / IP firewall nat :
just edit your NAT rule. Put IP range that you want to access to Internet in src-address. i actually forgot to tell you give me your IP addresses. So, For example if your L2PT users use this IP range(192.168.1.0/24), put this on src-address.
This NAT rule change the source IP address to your public IP that connect you to the internet.
I think it must be fix. But if the problem resist, contact me.
