Hello everyone,
I am having a problem with opening webmail using my primary wan. I think some firewall rule in webmail is causing this but i cannot check it since is not my side. I tested using second line and i can access it but i want to create a rule to redirect all traffic to that site through second line. Can you help me with this? I tested creating a mangle rule and markimg the traffic to the destination mail.domain.com and created a routing rule to use wan 2 for that routing mark exactly like this:
I am using version 6. This command does not work routing table add fib example_route. Also when i use the first method the page stays loading and says it took too long to response. I am posting the config export and screenshot a bit later today. Thanks for fast reply
