Hello guys!
I’m newbie working with Mikrotik devices and I’ve been asked to configure a Hotspot for the company for I’m working.
At the moment I have in my possession an RB941hAp with which I have been carrying out some tests, but for desplegation purposes I think I will need a higher performance device.
A friend of mine recommended me the Router 4011, but I would like to know your opinion.
Is that device a good idea for a hotspot? any idea of the maximum number of hosts that I can handle and the coverage area?
Is there a better device that fits better to my needs? (more than 100 hosts and a coverage area of 100 meters)
Any help would be very appreciated.
Regards Daniel.
I would suggest that you seriously consider the MikroTik Audience … especially if you exclusively dedicate one of the 5 GHz radios for the wireless backhaul assuming that you may need to add another Audience to provide FAR superior performance for the 100 hosts you want to service.
Audience is a tri-band (one 2.4 GHz & two 5 GHz) home access point with meshing technology. If you need Wi-Fi in a huge building with all kinds of obstacles, simply add more Audience devices to your network – with a press of a button they will sync seamlessly and create a single Wi-Fi network to cover the whole premises. The initial setup is also very simple – download the iOS or Android MikroTik app, it will connect to the router and guide you through a quick setup process.
