Router Board 750G
I just bought a brandnew routerboard 750g when i oned it and plugged a stright rj45 cable the number 1 port light goes on but i can t pick up the mac in winbox why is this i also tried assigning my card with its deafult ip 192.168.88.1 and tried logining via winbox and explore but does the same thing their is not packets being recived i can t login to the router board why is this ? and i am using a 24 volt adapter would that be the cause?
sorry guys but i repaired it
I think the default configuration script which puts a dhcp client on ethernet 1 makes it difficult for winbox to connect.
I usually use an alternate ethernet port (usually ethernet 2) when first connecting to an RB750 or RB750g.
Tom
By default mac-winbox server and neighbor discovery is disabled on 750G ether1. 192.168.88.1 IP address is already assigned to ether2.
thanks go it working configured etc went put it on the tower made a mistake it went to mac and 0.0.0.0 deafult now i can t login and way to login via mac ova wifi
