We deployed a virtual machine in Azure with the CHR image, using the version 6.49.beta.54
The image works fine, except that we are getting the following error from Azure:
Provisioning failed.
OS Provisioning for VM ‘*******’ did not finish in the allotted time. This error occurred too many times consecutively from image ‘mikrotik-chr-image-6.49b’. Make sure the image has been properly prepared (generalized).
The image was prepared and uploaded to Azure as explained in this tutorial:http://forum.mikrotik.com/t/chr-on-azure/134451/1
In contact with Azure technical support they concluded that “this VM is acting as a 3rd party appliance where basic commands are not provided and where Guest Agent is not configured”.
Also this "this must be reviewed with the 3rd party vendor and requirements must be met (https://github.com/Azure/WALinuxAgent). ".
Just as a note, we have other CHR VMs deployed to Azure that do not have the problem with provisioning, both Router OS v.6.47.stable
Is MikroTik going to address this provisioning issue in the incoming releases of the Router OS?
Thanks.
