Is it possible to install RouterOS in Zynq 7000 (ARM 32 bit) 1GB RAM?
ROS is tailored only to Mikrotik supported platforms so you have to try yourself.
ARM processor support does not imply support for the other components, especially given that a modified 5-series kernel is used.
- Not easily, not bare metal.
- With a custom kernel, you /might/ be able to, but I doubt the juice would be worth the squeeze
- Inside of a hypervisor (qemu), it might be possible to boot up the ARM CHR (it wants ARM64)...
FPGA implies custom peripherals and proprietary drivers, which is impossible for ROS, a closed-source system, to run. Even for open-source systems such as openwrt, there is still a great deal of adaptation work to be done.
