Router Recommendation
Looking for a router, previously was using a tp-link router with a single antenna. Problem reception issues, signals dropped significantly. Which one to go for? Need recommendations.
TIA
Based on the amount of info you provided as your requirements, I can safely say get a Mikrotik
Your description is very vague. Anything from this page, maybe buy the best your budget allows?
https://mikrotik.com/products/group/wireless-for-home-and-office
If you can be more specific then we can advise better.
get one with a double antenna. The range wouldn’t be an issue after that
RB4011 with wifi is a good investment.
I suggest the RB3011 as your Router/switch and for wireless I suggest the TP-Link EAP245 AC1750 Wireless MU-MIMO Gigabit Ceiling Mount Access Point
@mozerd, I wonder why you fancy the RB3011 (over e.g. 4011) so much?
@mkx
The 3011 has superior switch chip, it has Support for USB 3 providing additional storage and the SFP cage actually works great on GPON networks; users who want to use MOAB love this router …
the only advantage the 4011 has is its quad core CPU … but lacks GPON support and switch chip is lacking … plus no external storage for MOAB.
Thanks for that info M0zerd. Good tips! and Merry Xmas!!
Buy why the TPLINK AP. My CapAC is a decent AP for the price and ubiquiti LR AP for those that want premium performance.
For $20 more ==> Performance wise The TP-link AP IS VASTLY superior to the CapAC and to the Ubiquiti LR AP … That is why.
Wishing all a blessed Christmas and a happy, healthy and prosperous New Year.
I also stay with the 3011 over the 4011.
Too many reports about 4011 with wifi radios shutting down And I did see the SFP+ port shut down once in my test unit.
