Guys,
I’m not old in mikrotik, using it for many times but mostly did standard NAT with one subnet only. But this time I am doing a bit different things, and truly stuckup. Let me explain the scenario first.
- We will have 4 individual VLANS, OfficeLAN, IPT, CCTV, Management. The names are self explanatory. Management VLAN is for network equipment like switch, router, WiFi Controller, even AP. All these VLANs are published in a switch as L2.
- We need to provide Internet to OfficeLAN, as well as we also need to provide Internet to CCTV and IPT too.
- We need inter-VLAN routing.
- The router will have one MANAGEMENT port (which will be an untagged member of management VLAN, i mean connected to the switch’s management VLAN port. I know I can directly hook a winbox but please dont want to go for a debate here)
- The router will have WAN port as a standard port connected to ISP, but there will be a LAN port which will TRUNK all VLANs (if not separated for some other reason) to switch.
- I wish to make a inbound NAT (dst-nat) for IPT server and WLC (residing in two different subnets, aka VLANs).
- My IPT is on a untagged VLAN at switch. My WLC is on a both tagged and untagged VLAN on a switch. (I mean port). This is because APs initially registered using management port untagged, but then they use the tagged port for regular operation.
In future there may be a DMZ kind of thing on a different physical port.
This whole setup is perfectly working in my another setup using a full Cisco L3 switch and cisco routers. But as I’m shifting to mikrotik, here I messed few things up.
I made a fancy way initially and that kinda worked. But can’t do DST-NAT, and don’t know if NAT is “at all working”. My conf is given below:
# mar/19/2022 02:21:48 by RouterOS 6.49.5
# model = RB2011UiAS
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] comment=LAN1
set [ find default-name=ether6 ] comment=WAN1
set [ find default-name=ether9 ] comment=management
/interface vlan
add interface=bridge1 name=CCTV_VLAN vlan-id=17
add interface=bridge1 name=IPT_VLAN vlan-id=12
add interface=bridge1 name=Office_VLAN vlan-id=14
add interface=bridge1 name=mgmt_VLAN vlan-id=5
add name=VLANS
add name=dhpc_pool_OfficeLAN ranges=192.168.0.51-192.168.0.200
add address-pool=dhpc_pool_OfficeLAN disabled=no interface=Office_VLAN name=server1
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether1 untagged=ether9 vlan-ids=5
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=12
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=14
add bridge=bridge1 tagged=bridge1,ether1 vlan-ids=17
add interface=mgmt_VLAN list=VLANS
add interface=IPT_VLAN list=VLANS
add interface=Office_VLAN list=VLANS
add interface=CCTV_VLAN list=VLANS
add address=172.16.20.253/25 comment="ISP WAN IP" interface=ether6 network=172.16.20.128
add address=192.168.1.1/24 interface=mgmt_VLAN network=192.168.1.0
add address=192.168.0.1/24 interface=Office_VLAN network=192.168.0.0
add address=192.168.2.1/24 interface=IPT_VLAN network=192.168.2.0
add address=192.168.3.1/24 interface=CCTV_VLAN network=192.168.3.0
add address=172.16.20.252/25 comment="test WAN IP for IPT" interface=ether6 network=172.16.20.128
add address=192.168.0.0/24 dns-server=8.8.8.8 gateway=192.168.0.1 netmask=24
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface=ether6 src-address=192.168.0.0/24
add action=masquerade chain=srcnat out-interface=ether6 src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface=ether6 src-address=192.168.2.0/24
add action=masquerade chain=srcnat out-interface=ether6 src-address=192.168.3.0/24
add action=dst-nat chain=dstnat dst-address=172.16.20.252 to-addresses=192.168.2.10
add action=src-nat chain=srcnat src-address=192.168.2.10 to-addresses=172.16.20.252
add distance=1 gateway=172.16.20.129
/system clock
set time-zone-name=Asia/Dhaka
Note: I followed miktorik wiki and another post. Link given…
https://help.mikrotik.com/docs/display/ROS/NAT#NAT-DestinationNAT
http://forum.mikrotik.com/t/struggling-with-bridge-vlan-configuration/154446/1
I also have another question… Do I really have to make these bridge? I need to make the subnets, assign them to physical ports and surely to some VLANs too… I’m confused…
