Routerboard 1100 AHX2 POE not there?
let me start by saying that I’m new to MikroTik hardware so this may be an easy question to answer :slight_smile:
I have the following problem: Ethernet Port 13 should have POE functionality, but on the commandline I just don’t see it anywhere.
If I run /interface ethernet poe settings monitor [find] I get no results.
Does POE have to be actived first or am I doing something totally wrong?
It has PoE INPUT functionality, ie. it can be powered by PoE injectors.
The PoE menu is only for PoE OUTPUT functionality, ie. for powering other devices. The RB1100AHx2 doesn’t have PoE output functionality - only RB750UP and OmniTIK UPA have this feature, no other device has it.
Oh okay, that explains everything - thank you!
