I configured 2 routerboard 333 ROS 3.3 in nstrem dual ,5ghz turbo,framer policy best fit…The cpu is used 100% , bandwidth is 20 Mbits TCP.What cpu it takes to get 30 Mbits full duplex ???With 2 Routerboard 333 equipped frrom 3 wireless card R52H ???
I restart the router and nothing to do,the cpu is at 100% only when I tested the bandwidth,Without the test of bandwidth the cpu is a 5%.
Because of a cpu I may not have more bandwidth! What happens cpu need to have 30 Mbits for example?
try to lower tx power.uninstall all unneeded packages, install latest version, turn off connection tracking (if you are not using nat).and always do bandwitch test throught routers not from rb to rb
Hello
thank you very much for your support
I been testing several motherboard ALIX 3C2, PC, RouteurBoard, etc. !!!
RB333 should normally give TX/40 Mbits RX/40Mbits FullDuplex .
Version ROS 3.3 must have a problem I am going to test all versions…
