Routerboard 411 help
I’ve got a Routerboard 411 and before I try to re-invent the wheel… I had a few questions. I originally bought this with the intent of using it as a simple wireless access point, however my needs have changed and I am trying to turn it into a full fledged router.
In a nutshell, here is what I am trying to accomplish:
  • I currently have it hooked up to a small 5 port Linksys switch with a cable modem that assigns it’s address via DHCP, the RB411 and cable modem are both plugged into the switch respectively, as well as 1 client for testing.
  • I set eth1 as a DHCP client and it pulls the address from my provider as expected
  • I created a virtual ethernet interface and assigned a non-routable 10.x.x.x address to it which will be the basis of my intended LAN, complete with DHCP server, NAT, etc.
Is it possible to do what I am wanting to do with this in this scenario? Or am I better off getting say an RB750 and using dedicated ports? I’d like to do it with this if possible (as I don’t want to spend any more money if I can help it!)
I got as far as setting up the main ethernet port, but I can’t ping the virtual ethernet port from a client computer. For example, I setup my MacBook with an IP of 10.15.242.2, with a gateway of 10.15.242.1 for a quick test.
virtual ethernet is for MetaROUTER, you don’t need it
if you try to setup DHCP Server on the interface where your ISP’s DHCP Server is, that’s bad idea. you should connect your LAN to some other interface (in case of RB411 it’s wireless only)
