I have 450 routerboard, about 1 year old, and it appears to have died! The symptoms are that when first powered up the blue LED comes on for about half a second, and then goes out. The unit is totally unresponsive. I have tried 3 different power supplies.
Anyone else had this problem. Any ideas how I might repair it (even temporarily, long enough to down load the config!)?
I have compared some of the voltages on some of the ICs against a known working unit, and there are significant descrenencies on what I think are some voltage regulator ICs!
I have exactly the same problem with one of our older RB450s - old enough to be out of warranty. I took it apart, and saw three of the capacitors humped (one near the processor with the heatsink, the other two are between the internal power connector and the Ethernet ports). I just bought three new capacitors, and will try to change them soon. I hope this is the only problem.
The capacitors have been changed. The local electronics shop could not give me capacitors with the same capacitance, so I bought 1000uF ones. They are also slightly bigger, but just fit into the indoor case.
The board now boots okay, I can log in, so I suppose it works perfectly.
Many congratulations, and thanks for letting me know. I am definitely going to try it, but it will be a week or so before I can. I’ll let you know how I get on!
Just to let you know that I have now replaced the same three capacitors in my 450 unit, and bingo, its repaired.
MANY thanks for the tip. I used higher working voltage caps (25v) they were taller than the originals, so now lie on their sides. Looks funny, but works fine. I also use 470 uF caps.
I’d also like to know, if these are isolated issues, or some kind glitch with a particular series of RB450s - we have many of them in production, and this was the first one we sold.
I have experienced the same failure: 3 capacitors failed (bulged with some electrolyte vented) on a RouterBoard 450 purchased about 9 months ago. The capacitors are identified on the silk screening of the PCB as C810, C830 and C706. I have about four RB 450’s in use. It would be interesting to know if this is a design fault or simply a bad batch of capacitors. I have approximately 10 more RouterBoard450’s in use at cilent locations. A similar thing happened with a batch of Apple Airports and Lucent RG1000s about 8 years ago - we had deployed about 50 of them and ended up bringing them all back and replacing their capacitors with higher rating ones.
At least this type of failure is easily identified and fixed.
I see that the max temperature is 105, would that be high enough?
Sorry for the newb questions and introduction, im really not familer with this forum or how they work - but came across this thread through a google search!
I experience the same problem, thank to this thread i opened the case of my RB450 and found out that the capacitors in the RB450 is broken after about one year run time. At first i ordered a new AC/DC adapter but before i discovered this thread. I have ordered new capacitors and will come with a report if i get them in time and can replace them.
