Routerboard 600 rebooting
I have installed a new RB600 board with a daughterboard and it will randomly reboot… it may reboot after 15min or 20hours… I have saved the critical logs to disk and here is the error message “system error critical router was rebooted without proper shutdown by watchdog timer”. I am not watching any address in the watchdog. I do have “Automatic Supout” and “Auto Send Supout” enabled but it isn’t generating a file. I am also graphing interface traffic to the disk and it loses all history once it is rebooted? Could it also be removing the output files as well?
Specs:
RB600
RB564
18v ac adapter
RoterOS 3.2
Firmware 2.16
CPU Frequency 533MHz
how many wireless cards you have?
Try unplugging wireless cards from the RB600 and place all of them to RB564.
If you need more than 4 wireless cards and you don’t need additional ethernet cards then try RB604.
I don’t have any wireless cards. And I need all of the ethernet ports… I am only using this unit as a ethernet router.
Greetings!
Have you tried it at 400MHz? 533MHz is overclocked, and your CPU may not be dealing with it well.
If you must run it a 533MHz for some reason, try a cooling fan across the CPU.
Shea, are you still seeing issues?
I have this same problem with a RB600 with the same setup as you, except RouterOS 3.3, Firmware 2.12, and 400mhz CPU
RB600
RB564
18v ac adapter
No Wireless Cards
My watchdog reboots are random also, I have an address in the ‘watch address’ (my edge router which is up) but the ‘watchdog timer’ check box is not enabled.
I haven’t seen anything in the changelog that addresses this in newer versions.
I continued searching the forum and found this topic that firmware 2.13 fixed the issue.
http://forum.mikrotik.com/viewtopic.php?f=1&t=22868&start=0&st=0&sk=t&sd=a&hilit=watchdog
I will see if it addresses the problem I’m seeing since I do have an older firmware release
I am still having the problem.
We added a fan and the problem still exists but it will reboot after a couple of days instead of a couple times per day.
I am convinced it is a heat issue. This is an indoor, but not in an air conditioned environment.
I upgraded to ROS3.10 and FW 2.16 yesterday, so far 14Hr without a reboot. This is in a large outdoor cabinet. No AC, Cabinet Temp is around 106F-109F during the middle of the day when the sun hits it.
Shea,
Try upgrading to RouterOS 3.11 and to 2.16 firmware. There have been many changes since 3.2 including memory leak fixes. 2.16 RouterBoot was supposed to fix a rebooting problem.
Tom
