Hi there,
My first day (and night with a routerboard-device) and my first post here. Apologies if I haven’t lurked enough nor googled enough.
My setup is the following:
Internets with cable modem
RouterBOARD RB751G (with RouterOS 5.21)
192.168.242.1
box1 NetGear GS108T Switch (mgmt on 192.168.242.199)
Ethernet Ethernet
192.168.242.20 |
box2
Ethernet
192.168.242.245
Netmask 255.255.255.0
NAT and DHCP-server and DNS-forwarding enabled on RouterOS.
Both machines is assigned IP-addesses from routeros-box, using the same DHCP-scope.
box1 is working just brilliantly, accessing the internets and everything.
box1 can also ping and ssh to box2.
box2 can ping box1 and ssh.
box2 can’t ping routeros-router, nor can it access the internets.
Connecting box1 to the Netgear Switch it gets the same issues, no internets, only local access and no access to routeros-box. Connecting box2 to routeros-box directly makes this access the internets and all is well.
This leads me to think there is some sort of issue with the routeros box and the Netgear Switch.
I have tried:
- disabling all VLANs on switch.
- factory reset switch.
- upgraded firmware on switch.
- fiddled with Auto negotiation/Link speed/Full half-duplex/Flow Control (only switch) on both routeros and switch at no avail.
- replaced all cables.
- tested several switch-ports on both router and switch.
- enabled/disabled jumbo-frames on switch.
- tried arp enabled, disabled, and proxy-arp on routeros.
- removed all “deny”-rules in routeros firewall.
And now I’m out of ideas.. What more? Is it something easy I’ve missed I guess?
/Gustav
