RouterOS 7.25 — CAPsMAN roaming causes prolonged unicast traffic loss; disabling CAP bridge HW offload appears to fix it
We encountered a reproducible roaming problem between two MikroTik Wi-Fi 6 CAPs managed by CAPsMAN. Clients successfully associated with the destination AP but lost IP connectivity for several minutes. Disabling hardware offloading on the CAPs' Ethernet bridge ports appears to have resolved the problem.
Hardware and network configuration
  • Core router / CAPsMAN controller: MikroTik RouterOS 7.25.1, VLAN-aware bridge, providing inter-VLAN routing and DHCP.
  • Distribution switch: MikroTik CRS326-24G-2S+, RouterOS 7.25.1, hardware-offloaded VLAN-aware bridge.
  • CAP01: MikroTik cAP ax (cAPGi-5HaxD2HaxD), RouterOS 7.25.1, connected directly to the CRS326.
  • CAP02: MikroTik cAP ax (cAPGi-5HaxD2HaxD) connected through a CSS610-8G-2S+IN running SwOS Lite, with a fiber uplink to the CRS326.
  • Wireless management: New /interface wifi CAPsMAN, with traffic processed locally on each CAP.
  • VLANs tested: VLAN 18 (WPA3-PSK management SSID) and VLAN 50 (open guest SSID with captive portal).
Both CAPs use br-lan, with ether1 as a bridge port. CAPsMAN assigns VLAN IDs through the Wi-Fi datapaths. Bridge VLAN filtering on the CAPs is disabled; VLAN tagging is handled by the Wi-Fi datapath.
Symptoms
When an iPhone roamed between CAP01 and CAP02:
  • Wi-Fi association and authorization succeeded, with good signal strength.
  • The client retained its valid DHCP address.
  • Internet connectivity and ping to the default gateway failed, sometimes for several minutes.
  • The client repeatedly transmitted ARP requests for its gateway.
  • Packet captures on the core router showed those ARP requests arriving and the router immediately generating correct unicast ARP replies.
  • During the failure, captures on the destination CAP showed outgoing client ARP requests but not the corresponding incoming unicast replies.
  • Bridge MAC tables on the router, distribution switch, and CAPs showed the client's MAC learned on the expected ports.
The problem occurred in both roaming directions and on both tested VLANs. The network was essentially idle.
Disabling hardware offloading on relevant CRS326 bridge ports did not resolve the issue.
Diagnosis and workaround
We suspected a stale hardware forwarding state associated with roaming.
While the iPhone was associated with CAP01 but unable to ping, we executed the following command on CAP01:
/interface bridge port set [find where interface=ether1] hw=no
Ping immediately began working, without disconnecting or reconnecting the iPhone, renewing DHCP, or making any other changes.
We applied the same setting to CAP02.
Subsequent roaming tests in both directions succeeded. During one handoff, two pings were lost, but connectivity recovered normally rather than remaining unavailable for several minutes.
Current assessment
Disabling Ethernet bridge hardware offloading on both CAPs appears to be an effective workaround.
The evidence strongly implicates hardware-offloaded bridge forwarding or stale forwarding state on the CAPs. However, we have not established whether this is a RouterOS/IPQ-PPE defect or whether changing the offload setting merely resets problematic forwarding state.
We are retaining hw=no on both CAPs while monitoring longer-term stability.
Questions for MikroTik:
  1. Is this a known issue with IPQ-PPE hardware offloading on cAP ax devices running RouterOS 7.25?
  2. Are there known interactions between hardware bridge offloading, local CAPsMAN forwarding, VLAN-tagged Wi-Fi datapaths, and client roaming?
  3. Is there a RouterOS release that specifically addresses this behavior, or is disabling bridge hardware offloading the recommended workaround?
I'm not Mikrotik :-), but yes, this is in fact the case. It's documented that the ipq-ppe hw offloading is unfinished and shouldn't be used.
It may be worth reporting your findings, but because it's unsupported, who knows whether this particular instance of failure will (or should) get focus.
