RouterOS and Alix 2d2
First of all sorry if I am creating a duplicate issue on this matter. I’ve searched this forum and many others however and I did not see this exact issue so far and that’s why I am opening a new thread.
I am trying to install RouterOS 6.27 (I’ve tried with 5.x, 4.x, 3.x and 2.x for that matter also) on an Alix 2d2 and I can’t manage to get it done.
I am using Netinstall to make it happen, I’ve tried installing it directly on the CF card (tried with all packages as well as with the upgrade package only) and also using PXE (using the tutorial on the MikroTik wiki). I’ve changed 3 CF cards because I’ve read that some Sillicon Power CF card controllers had some issues in the past, so I used also SanDisk and Lexar CF cards.
Everything failed!
Like I said, I am using Netinstall to write the files on the CF card, they are written properly, I am inserting the CF card in the Alix 2d2 board, powering it up, I am connecting on the serial port using baud 9600 8N1 (no flow control), I can see it booting properly for the first time:
PC Engines ALIX.2 v0.99h
640 KB Base Memory
15360
31744
48128
64512
80896
97280
113664
130048
146432
162816
179200
195584
211968
228352
244736
261120 KB Extended Memory
01F0 Master 044A SILICON POWER
Phys C/H/S 15538/16/63 Log C/H/S 974/255/63 LBA
SYSLINUX 3.84 2009-12-18 EBIOS Copyright (C) 1994-2009 H. Peter Anvin et al
Loading linux...................
Loading initrd.rgz...........ready.
Then it waits for a couple of seconds (~5s), reboots and after the reboot it outputs the following:
640 KB Base Memory
15360
31744
48128
64512
80896
97280
113664
130048
146432
162816
179200
195584
211968
228352
244736
Missing operating system
Using different RouterOS versions the error is either “Missing operating system” or “No boot device available, press Enter to continue.”.
Can someone please advise?
Kind regards,
Serban
Use 6.26 netinstall and upgrade after is running.
It is can help, make sure your TTY client is set to use the default 9600 baud rate for RouterOS x86 and wait several minutes for the boot to complete.
Stop resurrecting old topics
