RouterOS and e-mail of failed logins and other system info
I’ve glanced through the forums and found a few posts about emails but nothing about getting mails when there are failed login attempts on your mikrotik router. I was wondering how people do it. So far, I have done this:
/system logging action> print
Flags: * - default
 #   NAME             TARGET REMOTE
 0 * memory           memory
 1 * disk             disk
 2 * echo             echo
 3 * remote           remote ::
 4   1                remote ::
 5   2                remote ::
I have sent myself a test mail and it works. How can i get the router to send me more info, will the remote rules (4 & 5) be enough for this?
Thanks.
Mine works. V4.16 on RB433AH. This is my settings:
[admin@test] /system logging action> print
Flags: * - default
 0 * memory                                                  memory
 1 * disk                                                    disk
 2 * echo                                                    echo
 3 * remote                                                  remote 0.0.0.0:514
 4   email                                                   email
Then for a test
/system logging
print
set X action=email
Replace X with the line number of the topic you want emailed.
I set “topics=critical” as email and then tried to login with a bad password. The email was sent.
That’s why having the “tls=yes” parameter in the server declaration section would have been so usefull. Actually, it’s only available on the “send” command line, so it wouldn’t work in my case (gmail).
I’m still on V4.16, but I hear rumors that the “/tool e-mail” settings in V5.x has a tls setting.
ADD: You don’t need tls to send email to a gmail account.
You need tls to relay email to a non-gmail account using your gmail account.
You must use port 25 instead of 583 tho. My nslookup shows I can use server = 74.125.157.27 port 25 to send to gmail accounts. EDIT: This ip works for me. I just checked it.
With gmail, your email may end up in your “spam” folder. Mine did. Check there too.
Some email servers are starting to use a spam filter that blocks email from source ip/subnets that are considered “residential”. If you obtain your ip by DHCP, and it is not “persistent” (“static” ip assigned by dhcp to your mac address), then your ip/subnet will probably end up on this list some day.
Negative:
v5.4:
/tool e-mail set
address  from  password  port  user
Thx for this info (didn’t know that). But still… I have this security feature available, it works, why wouldn’t I want to use it? :slight_smile:
MT, please add support for tls setting to the e-mail menu.
So much for rumors. :frowning:
@elgo: I agree with you. The tls setting in “/tool e-mail” would enable your router to send email even if the receiving email server thinks your router is “residential”.
Tried that but not working for me, I am on 5.4, when setting up I get:
/system logging> set 3 action=mail
input does not match any value of action
I put together a script a while back for this purpose. I wanted to be alerted whenever anyone logged into the router or when anyone failed to log in. This was my solution:
http://forum.mikrotik.com/t/is-it-possible-to-run-a-script-on-login/55422/1
The script can be easily modified to search for any text you would like. The example searches for logs that contain the text “logged in” or “login failure”.
:local currentBuf [ :toarray [ /log find message~"logged in" || message~"login failure" ] ] ;
If you only want to check for login failures, something like this:
:local currentBuf [ :toarray [ /log find message~"login failure" ] ] ;
See the script for the full code…
