I’ve got a problem with shoutcast, a program for broadcasting internet radio. I opened the port on the router (port 8000) but when I type my IP into the internet browser followed by port :8000 I do not the Shoucast page as I should.
you also need port 8001 for SC to work properly
further more, if you assign some custom port N for SC server, you need to open both ports N and N+1, because of the way SC works
D3. I’m behind a firewall/proxy. Can I still use the DNAS to broadcast?
Answer: Tricky question. Users behind proxies cannot. Users behind NAT devices can, provided the same port the SHOUTcast Radio server runs on is set up to forward from the NAT device to the SHOUTcast Radio server. Users behind firewalls can also get a hole punched so listeners can penetrate. If broadcasters also need to get in from the outside world, you should open the hole for PortBase + 1 (i.e. id SHOUTcast Radio runs on 8000, 8001 should be open for broadcasters to get through as well.)
