In the following figure, the script I wrote via routeros api gives an error. What’s the right way?
$API->write('/ip/hotspot/cookie/remove');
$API->write('=user=155548745');
$OKU=$API->read(false);
$ARRAY = $API->parseResponse($OKU);
print_r ($ARRAY);
Error Code :
[code][!trap] => Array ( [0] => Array ( [message] => no such command prefix ) )
Thanks…
Try remove by id not by name.
In terminal of WinBox
/ip hotspot cookie remove ?
I see
Remove specified item (or several items).
– List of item numbers
i.e. very probably it needs numbers i.e. I think ids, something like
$API->write('=.id=*ABCDEF');
Sure you need find value of field “.id” for required user first…
In terminal it is command like:
:put [/ip hotspot cookie find user="155548745"]
Or try condition:
$API->write('?=user=155548745');
From API docs unclear if this work in such way
