RouterOS as wireless router
Hi, i need help,i want to setup my routeros to work as standard wireless router.
I added two ethernet cards,and one wireless card on some old PC, and installed routeros.
I added ip addresses to ether1 (public interface) and wlan (local interface for conecting my computers),PPPoe out,dhcp server,masquerade ether1,and pppoe out,but it does not work.
PPPOE is connected to my isp,dhcp server is running,my computers obtain ip addresses from dhcp pool,but nothing,i can ping for example google from mikrotik,but when i try to open some web page on computers,or to ping google nothing happens :confused: :confused: :confused:
Can somebody help to solve this problem? :slight_smile:
Greetings!
Your info is limited, but since you can ping Google from the RouterOS box, I will presume all is ok there.
Can you ping from the wireless clients by IP?
If not, can you ping your gateway from wireless clients?
In your dns settings, do you have allow-remote-requests=yes?
Hi, the problem was in configuration of DHCP server.I put static ip addresses to all my computers and remove dhcp,and finally it works! thanks for help anyway. :smiley: :smiley: :smiley: :smiley:
