RouterOS get uptime days code is:
put "Uptime: $[:if ([:len [:find [/system resource get uptime] "w"]] != 0) do={([:pick [/system resource get uptime] 0 ([:find [/system resource get uptime] "w"])] *7 + [:pick [/system resource get uptime] ([:find [/system resource get
uptime] "d"] -1) ([:find [/system resource get uptime] "d"])])} else={[:pick [/system resource get uptime] ([:find [/system resource get uptime] "d"]-1) ([:find [/system resource get uptime] "d"])]}] days"
The output result is:
Uptime: days;Uptime: 18 days
I have a problem.
The output has more “Uptime: days;”
I don’t want the output to have the “Uptime: days;” symbol.
Or is there a better way for people to do this?
:put [/system/resource/get uptime
11w2d15:59:17
Thank you reply.
I need the unit to be days.
Try:
# rextended's function (thanks Master)
# Convert uptime to seconds
:global timetoseconds do={
:local inTime $1
:local wPos [:find $inTime "w" -1]
:local dPos [:find $inTime "d" -1]
:local itLen [:find $inTime "." -1] ; :if ([:typeof $itLen] = "nil") do={:set itLen [:len $inTime]}
:local itSec [:pick $inTime ($itLen - 2) $itLen]
:local itMin [:pick $inTime ($itLen - 5) ($itLen - 3)]
:local itHou [:pick $inTime ($itLen - 8) ($itLen - 6)]
:local itDay 0
:local itWee 0
:if (([:typeof $wPos] = "nil") and ([:typeof $dPos] = "num")) do={:set itDay [:pick $inTime 0 $dPos] }
:if (([:typeof $wPos] = "num") and ([:typeof $dPos] = "num")) do={:set itDay [:pick $inTime ($wPos + 1) $dPos] }
:if ([:typeof $wPos] = "num") do={:set itWee [:pick $inTime 0 $wPos] }
:local totitSec ($itSec + (60 * $itMin) + (3600 * $itHou) + (86400 * $itDay) + (604800 * $itWee))
:return $totitSec
:local upd ([$timetoseconds [/system resource get uptime]] / 86400)
:put "Uptime: $upd days"
Please use the code tag, to avoid Cool smile face when posting code pre formatted.
Key </>
My function timetoseconds is correct…
http://forum.mikrotik.com/t/convert-uptime-to-date-and-time/157724/5
but if already is v7.12.1 (and up) just simply…
:put "Uptime: $([:tonum [/system resource get uptime]] / 86400) days"
That's great.
Effective and simple code.
Thank you.
Keep in mind, as I have recently found out, after ~500 days it restarts back to 0d00:00:01.
