routerOS mis-reports the device as the non passive cooling version; ie main difference being the CCR1009-7G-1C-1S+ to have: wider form-factor, a 1.2Ghz CPU with active cooling (fans) and dual power supply
current-firmware: 6.46.6
I am running these commands in the Mikrotik CCR1009-7G-1C-1S+PC
As one of the main difference between the 2 devices are CPU frequency
I tested the following:
downgrade my passive-cooled version of CPU speed (in system > routerboard > settings) => logs at boot and /system routerboard print are showing “cpu not running at default frequency”
bring back CPU speed to 1Ghz => the notification messages are gone
Conclusion:
routerOS reports the passive-cooled board as it as beeing the non-passive-cooled version (which features a 1.2Ghz CPU version), but routerOS is capable of finding out what is the “real” default CPU speed between the passive-cooled version.
So all is OK - marking thread as resolved
