RouterOS Login Welcome Message: How To Replicate?
So everyone knows when you get a device from the manufacturer and you first log into it, a message appears stating that this is the default configuration hit remove script to reset this device, or something to that affect.
I’d like to know how to produce a message upon login. We’d like to use it for notes the user should be aware when configuring this particular board. Anyone know how to do it? The only thing I’ve found is \system note. This shows the message in a terminal but can be overlooked. I’d like the GUI window that pops up when you first log into RouterOS with winbox. Any and all help is appreciated.
hi
you can set your message only in system note for show in terminal.and can’t create any message for graphic interface only contact with mikrotik office.
it is hard to do?
