RouterOS opened 181 tcp port? what is it? how to disable?
Starting Nmap 7.31 ( https://nmap.org ) at 2017-02-16 17:13 RTZ 4 (ceia)
Nmap scan report for xxx.xxx.xxx.xxx
PORT STATE SERVICE
181/tcp open unify
RouterOS is not using this port. Are you using nmap on the correct device? Maybe you have port forwarding.
i am block all incoming tcp packets with firewall rule, but this tcp 181 still OPENED!
(same as tcp port 2000 - service Btest server, if they enabled!)
firewall nat - is clean!
[root@MikroTik-Z] > /ip firewall filter print
0 chain=input action=reject reject-with=icmp-network-unreachable protocol=tcp log=no log-prefix=""
[root@MikroTik-Z] > /system routerboard print
routerboard: yes
model: 951Ui-2HnD
serial-number: 7175060DB1F2
firmware-type: ar9344
factory-firmware: 3.33
current-firmware: 3.33
upgrade-firmware: 3.33
[root@MikroTik-Z] > /system package print
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 6.37.1
1 security 6.37.1
2 wireless 6.37.1
3 advanced-tools 6.37.1
4 dhcp 6.37.1
5 X ppp 6.37.1
6 routing 6.37.1
Set log=yes and check log if you are scanning the correct device :slight_smile:
RouterOS does NOT use such port. Plus, you have firewall, as you demonstrated.
Yes! Device is correct - MikroTik! in log window - scan flood!
what is next?
Remove your reject rule and try this:
/ip firewall mangle
add action=log chain=output protocol=tcp src-port=181
And then connect to port 181 with something (e.g. telnet).
This is what you’ll see for closed port:
14:50:49 firewall,info output: in:(none) out:internal, proto TCP (ACK,RST), <server>:181-><client>:36382, len 40
And this would happen for open one:
14:50:52 firewall,info output: in:(none) out:internal, proto TCP (SYN,ACK), <server>:181-><client>:45958, len 60
14:50:52 firewall,info output: in:(none) out:internal, proto TCP (ACK,PSH), <server>:181-><client>:45958, len 68
dst-nated before this router, sorry! thx for help!
