RouterOS to SwOS vLAN Help
I am trying to set up a CRS317-1G-16S+ as a core switch behind a RB2011UiAS. I’m replacing my current HP Procurve switch and want to minimize the changes necessary on my router.
Right now, I’m just trying to get vLAN traffic passed through the switch. I have my router (ether 05) connect to the switch (SFP16). I have a laptop connected to the switch (SFP15). I am trying to set up SFP16 as a trunk port and SFP 15 as an access port.
RB2011UiAS vLAN Configuration:
CRS317-1G-16S+ vLAN Configuration:
Any help is appreciated.
Check out this setup example, maybe it will help you with configuration.
Thanks! The instructions helped, but in the end it turned out to be with how I was configuring an access port for management and inadvertently created a switching loop.
