weber, please post your /ip dns export compact.
omidkosari, I will check what is wrong with your ticked and why you didn’t get reply.
sergejs, it is strange but it’s ok now. Probably, webfig/browser cache issue…
Thanks . Still waiting ![]()
had no problems with 5.17 on 700-series but also tried it on a rb493 - it totally screwed switch setup, also wan throughput went almost to 0, downgrading to 5.16 solved the problem, now I’m afraid to use it on 493 series (and I have a lot of them)
edit: switch setup was - eth3-eth8 - masterport eth2, eth2 in bridge1, vlan id=2 on bridge1, eth9 in bridge2, ros5.17 didn’t allow eth2 in bridge1 and disabled it, after removing masterport from eth3-eth8 and adding eth2-eth8 to bridge1 wan throughput went to 0
Which version fixed it?!
v6.x has fix for the problem.
5.23 version will have fix for Winbox graphs menu.
I’ve asked which version fixED it, because it is already working on 5.22!! ![]()
Edit: 5.21 doesn’t work; 5.22>>works fine, so i’ve got my answer.
So it means 5.22 fixed it.
