RouterOS v6.41.1 DHCP Basic Accounting
We are running RouterOS v6.41.1 and testing DHCP Server Accouting feature added by Mikrotik. We are using freeradius as radius server. Auth is done by mac address and client receives IP from pool,
everything is ok auth works and also accounting works, On the accouting table in freeradius rows are added but username field is empty? What does send routeros in this field to radius server?
RouterOS v6.41.1 + DHCP Server Accouting + freeradius
When is set radius to “yes” client got IP address from radius, is created simple queue - radius reply OK but accounting in radius is not working
when is set radius to “accounting” , radius accounting is working but no radius reply. Client got IP from local pool.
What is the solution to set accounting + radius reply ?
I’m also having the same problem
