RouterOS v6.49.5- IPv6 settings
I would like to play with IPv6, however I can’t find any IPv6 related settings in the web interface. Any ideas how to access that?
For example settings like IPv6 DHCP settings, firewall …
This is what I can see in the menu (attachment):
I think you have to add “Extra packages” manually (and to be specific: ipv6-6.49.5-arm.npk).
Might be better to upgrade (to LTS 6.49.8 or Stable 6.49.10) while you are at it.
Yes, I had it disabled in System->Packages, can see it now.
Also ugpraded to 10.
hello friends
I have two users on the Mikrotik router that connect to my router vpn. When one of them goes online, the second user goes offline.
My connection is l2tp type.
And my router version is 7.3.1
The message it displays is terminating… - hungup
:smiley:
Welcome on the forum, you might want to create a new topic. Add you config to it to get some help::
/export file=anynameyoulike
Just remove serial and any other prive information like public IP
